Forums >> Revit Building >> Technical Support >> DOOR SCHEDULES
Thu, Feb 28, 2008 at 3:11:36 PM | DOOR SCHEDULES
doza10
IN MY DOOR SCHEDULE I HAVE A DOOR THAT IS A 3070 W/SIDE LIGHT. IT IS 4'-8" TOTAL ACROSS AND IS 7'-4" IN HEIGHT AND IT IS READING THAT WAY IN MY SCHEDULE. I WANT IT TO READ 3'-0" X 7'-0" IN MY SCHEDULE BUT IT IS COMING UP AS 4'-8" X 7'-4". WHAT DO I NEED TO DO SO THAT IT WILL READ THE RIGHT WAY?
Thu, Feb 28, 2008 at 3:42:00 PM | DOOR SCHEDULES
maranelloboy
3 Stars: 2 Votes
It may be that the family's Width parameter is the overall width (door with side light).  The Width and Height parameters are what Revit looks at when building a schedule.
Fri, Feb 29, 2008 at 8:51:37 AM | DOOR SCHEDULES
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
maranelloboy is correct about the width parameter. We use the "Width" Parameter to determine the 'panel' size, and "Rough Width" to determine the 'overall' width. The same goes for Heights. I have to add formulas to the parameters to get all of the widths heights to read correctly in a schedule.
Example:
Rought Width = Width + (Frame Width * 2)
This is only an example. Some of my formulas are more complex than this, but I am able to acheive all desired entries in a Door Schedule and the are still parametric.
Schedules: Ie Door schedules!
Fri, Jul 11, 2014 at 2:58:22 PM
Nested Door Families and Door Schedules
Mon, Nov 8, 2010 at 2:56:46 PM
How to Print Large Door Schedules Revit 2009
Wed, Jan 21, 2009 at 12:28:45 PM
Managing Door/Window Schedules
Mon, Jun 18, 2012 at 7:17:06 AM
Necessary to reinvent the wheel with door schedules?
Wed, Feb 10, 2016 at 9:48:56 AM
Page generation time: 0.2853
