Forums >> Revit Building >> Technical Support >> Railing at stair bottom!
Thu, Feb 28, 2008 at 10:41:50 AM | Railing at stair bottom!
jmiller
I am trying to place a railing at the underside of a stair that goes up to a loft area, and i need a railing along another stair that leads to the basement, i attached a pdf file of what i am trying to do is there a easy way to make the railing die into the stringer of the loft stair?
Thanks
Thu, Feb 28, 2008 at 10:57:33 AM | Railing at stair bottom!
You will not get the standard railings to do this.  Since this is a one place occurance, you cold do this as an in-place family.
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:39 PM
Stair Handrail Extensions
Fri, Apr 11, 2008 at 10:48:31 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
Railing Extension Problem
Mon, Dec 5, 2016 at 12:52:29 PM
Railing wont host to stair created in design option
Mon, Oct 24, 2011 at 3:54:39 PM
Page generation time: 0.2148
