Forums >> Revit Building >> Technical Support >> Floor pattern control in Revit 2008
Thu, Feb 28, 2008 at 8:52:47 AM | Floor pattern control in Revit 2008
profbrody
How do you turn off the floor pattern in Revit 2008? It's not listed in the visibility/graphcis over-rides menu any more...
Thu, Feb 28, 2008 at 9:27:25 AM | Floor pattern control in Revit 2008
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Sure it is. Look in the VG box. There is a column for Surface Patterns. Click on the box and you will get the Override Button. This button will bring up a box and in there is a checkmark box labeled "Visible". Uncheck it.
Look at the attached image for the location of the Override.
Thu, Feb 28, 2008 at 10:18:29 AM | Floor pattern control in Revit 2008
profbrody
That was it - thanks! Wasn't the floor pattern listed as a separate category in the past, along with slab edges and the like?
Thu, Feb 28, 2008 at 10:28:51 AM | profbrody
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting profbrody from 2008-02-28 10:18:29
"That was it - thanks! Wasn't the floor pattern listed as a separate category in the past, along with slab edges and the like?"
yes it was, this is new for RAC 2008
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Hiding Floor Surface Patterns in Revit 2008
Wed, Jun 13, 2007 at 1:14:16 AM
how to download pattern in revit? 2009, 2008 etc...
Thu, Aug 13, 2009 at 7:01:11 AM
Inconsistent Floor pattern for shape edited floors
Thu, Sep 13, 2007 at 11:30:11 AM
Floor pattern -- masking floor pattern
Mon, May 23, 2005 at 11:51:48 AM
Page generation time: 1.6193
