26 Users Online (24 Members):
Forums >> Revit Structure >> Technical Support >> Need a little help...
Hi, I'm new to Revit. On my floor plan I can see trees and hidden lines from my site plan. How do I make these invisible on my floor plan? Also, on my second floor plan I can see the garage. How can I remove this from 2nd floor plan sheet? Sorry about such basic questions. I am really new to Revit. Thanks in advance. Vanostran
In the plan, type VG (Visibility/Graphics). Scroll through the list until you see plantings and uncheck it. For the second floor issue, are you seeing the roof over the garage? You need to adjust your view range
Not sure how your project is setup but you might find a plan region in the area of your garage will help you control what you want to see there. You can set that area up with its own view range.
You can also click on the object you dont want to see, click the sunglasses and hide catergory or element. On the floor plan, if you dont want to see the plan below, right click over the plan, click properties, and click the underlay and choose none. I am pretty new, there might be faster ways.
thanks everyone. Found my problem. Jon
