Forums >> Revit Building >> Technical Support >> Attach MEP lights to Arch Grid
Wed, Feb 27, 2008 at 4:38:29 PM | Attach MEP lights to Arch Grid
InVision
I've linked in the MEP Revit model into my architectural model but the MEP ceiling lights don't cut into the ceiling grid.  Is there any way to do this?
Thu, Feb 28, 2008 at 10:50:13 AM | Attach MEP lights to Arch Grid
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
This is not possible at this time. I had to create/maintain the ceiling element in the MEP model to get this to work. I realize this is not the ideal solution but it worked for the model I was creating. I really hope Autodesk addresses the issue of linked files for a future release. We are restricted to using links because our MEP work is done by other companies.
The other solution is to use a workshared file (central file) and create all objects in one model.
Thu, Feb 28, 2008 at 10:59:30 AM | Attach MEP lights to Arch Grid
InVision
Thats kind of what I figured you were going to say.  Defeates the whole BIM purpose by having them not work together doesn't it?
Thu, Feb 28, 2008 at 11:03:55 AM | Attach MEP lights to Arch Grid
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I agree that this severly limits the idea of working in all disciplines. I am sure there will eventually be a solution though. I am just trying to work around it until then. There are so many more benifits to the program that do work correctly, and I am certain that when the program is more developed I will be glad I stuck with it.
Tue, Feb 9, 2021 at 7:21:18 AM | Attach MEP lights to Arch Grid
hanbyjm
Bump: any updates on this issue?
Tue, Feb 9, 2021 at 8:26:08 AM | Attach MEP lights to Arch Grid
Revit has always had a plain ceiling which basically has no properties, it is just a plane to host ceiling elements.  Use the ceiling tool and place it at the same elevation as the architecural one and place your fixtures according to the architectural grid.
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
architect linked RCP lighting
Wed, Jun 9, 2010 at 8:01:30 AM
Lights in MEP or Achitecture
Fri, Oct 28, 2011 at 3:01:38 AM
Turning off the arch grid
Sat, May 15, 2010 at 8:05:45 AM
Lights in Ceiling Grid
Sat, Feb 4, 2006 at 12:49:43 PM
Page generation time: 0.2541
