Forums >> Revit Structure >> Technical Support >> changing text style in a grid bubble
Wed, Feb 27, 2008 at 3:01:03 PM | changing text style in a grid bubble
chertila
I am trying to change text style in a grid bubble, but in “type properties” box I can not find this parameter. Does anybody know how to do it? I do not want to change all of them in system family. I want to create new system family, say grid3/4. How can I do it? Thank you.
Thu, Feb 28, 2008 at 1:37:33 AM | changing text style in a grid bubble
johnda
Select the grid >Go to proerties >Go to Edit > note the name of the SYMBOL <eg Grid Head> close down the properties box. Now go to Annotations in th Project Browser & look for the SYMBOL <eg Grid Head> select it, right click, select edit.
Now make the changes you need and save it back to the project.
Best of luck
John A
Thu, Feb 28, 2008 at 12:37:45 PM | changing text style in a grid bubble
chertila
thank you, John. it was great jump. i spend much more time, because i wanted many different stiles on one level. and i still do not understand, why i can not save new styles under family-grid as multiple types. every time i load new style, it creates new families. to be short, visibility is great, but filing is ugly.
Thu, Feb 28, 2008 at 2:33:08 PM | changing text style in a grid bubble
johnda
You can create as many different style grid markers as you like & then change them by selecting the different style under SYMBOL
John A
Column grid text too wide to fit in bubble
Thu, Jul 1, 2010 at 8:32:06 AM
3d model text in grid bubble
Mon, Apr 27, 2015 at 11:57:55 AM
Grid Lines - Instance based text in grid line family
Mon, Jul 23, 2018 at 2:17:14 PM
Grid Bubble formatting between projects
Sun, Oct 26, 2014 at 8:33:04 AM
Column Grid Text
Tue, Dec 11, 2007 at 9:33:36 AM
Page generation time: 0.5190
