15 Users Online (13 Members):
Forums >> Community >> Newbies >> arc in wall
9 Posts No Rating |
can anyone help me create a wall with the arched cutout similar to this http://www.revitcity.com/gallery.php?action=view&gallery_id=5731
Yup... switch to an elevation view and click on the wall and then Edit the profile. Use the Split tool to break the bottom boundary line and then draw in new lines for the arch. make sure that the boundary ends up a closed loop. Click Finish. Or you could create an In-Place wall and uses solids and voids.. Justin www.revitup.co.za
63 Posts No Rating |
You could also create a generic wall based family, that has a opening or void cut thru the wall, this could be controlled with parameters & would be usable in other projects you may create. Best of Luck John A.
Arc Walls with curved top? |
Thu, Aug 7, 2008 at 2:04:21 PM
how to make an arc reveal in a wall in revit? |
Fri, Oct 22, 2010 at 7:17:06 AM
Divide arc by length |
Fri, Sep 7, 2007 at 6:17:46 PM
Arc Wall Profiles |
Tue, May 23, 2006 at 1:22:01 PM
Convert wall from thick to think at corner fillet-arc |
Fri, Aug 11, 2017 at 8:03:41 AM
