11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Co-ordinating between Structural and Architectural
7 Posts No Rating |
I am trying to coordinate between Revit Structure and Revit Architecture. I have linked an Architectural file into a new Structural file but some of the walls in the linked Architectural file don't show up. All the walls that are classified as an existing wall are showing up but the new construction walls are not. I don't know if it is something that has to be set in the Default settings or if it something I am doing wrong. Please help.
Is your phase filter under VP set to show all? If so, then check your VG / REVIT LINKS and verify that the linked file is set to show all.
7 Posts No Rating |
WWHub, My phase filter is set to show all but I havn't checked the VG for the Revit link. I will try that Thanks.
7 Posts No Rating |
everthing in the revit link is turned on and it still doesn't show up. What's next???
Try setting the discipline in the VP to be Coordination.
7 Posts No Rating |
I have tried changing the the discipline in the VP as well but that didn'[t change anything. I have been told that there are some defult settings that have to be set up before this can work properly. Does anyone know what they are?? Thanks
Edited on: Mon, Apr 7, 2008 at 1:57:25 PM
I may be way off here but I thought i once heard that the load bearing or non load bearing parameters make a difference as to what shows up in the structural program. Never linked a file to structural but.....take a look. let us know.
7 Posts No Rating |
Thanks I will try that and tell you how it goes.
Architectural Vs. Structural Linking |
Tue, Feb 19, 2019 at 10:42:28 PM
Manipulate Structural Grid in Architectural model |
Mon, Nov 14, 2011 at 4:11:47 PM
Structural vs Architectural Walls |
Mon, Feb 4, 2019 at 11:31:59 AM
hide architectural wall layers in structural views? [ 1 2 ] |
Fri, Apr 19, 2013 at 3:04:09 AM
24
linking structural file to architectural file |
Tue, Nov 19, 2013 at 12:04:49 PM
