Forums >> Revit Building >> Technical Support >> Need help building stucco mass
Tue, Feb 26, 2008 at 11:44:21 AM | Need help building stucco mass
siar6100
I'm trying to build a stucco mass that wraps around from the adjacent wall.  I was going to create a mass then do wall by face to achieve this.
 But when I try and finish the mass, i get two error messages.
1. can't regenerate family mass 2.  Edit family to modify it.
2. mass contains no solid geometry.  Floor area faces, volume, and surface area, wont be computed.
At this point revit will not allow me to finish the mass so that I can attach wall by face.
Anyone have any suggestions or other ways of achieving this stucco mass?
Thanks!
Tue, Feb 26, 2008 at 11:45:25 AM | Need help building stucco mass
siar6100
Oh and also I wanted to know how I can attach the same wall by face to the underside and top of the mass.
Tue, Feb 26, 2008 at 11:52:43 AM | Need help building stucco mass
siar6100
Well I was able to recreate another mass by using a different work plane, so that part is solved.
But I'm still wondering if this is the best way to create this object.
Thanks!
Tue, Feb 26, 2008 at 12:03:05 PM | Need help building stucco mass
siar6100
here is a section of that stucco projection.
Revit will not allow me to cut geometry from the projection so that the overlapping part is flush with the vertical wall.  Any suggestions?
Also how would I attach a top and bottom to complete the stucco mass.
Thanks!
stucco bands
Wed, May 21, 2008 at 3:39:27 PM
Model Hatch for Stucco Pattern
Thu, Jul 12, 2012 at 2:18:32 PM
irregular patterned stucco wall
Tue, Jan 27, 2009 at 9:03:41 AM
How to add stucco to face of cmu wall
Sat, Oct 23, 2010 at 2:59:05 PM
Editing a Mass to attach to roof.
Mon, Jun 16, 2008 at 10:53:43 AM
Page generation time: 3.6106
