Forums >> Revit Building >> Technical Support >> Elevation View
Mon, Feb 25, 2008 at 4:10:02 PM | Elevation View
InVision
Is there any way to segment or curve an elevation view line?
Mon, Feb 25, 2008 at 4:54:16 PM | Elevation View
eldados
eldados Avatar
4.5 Stars: 8 Votes
in the view itself select the crop region and you can split it into segments, you won't be able to change the plane though, if you want to step the view, use a section.
you cannoy curve the elevation (why??)
Integrator
KarelCAD
Mon, Feb 25, 2008 at 4:58:58 PM | Elevation View
InVision
I have a long curved hallway I need an elevation of and having only a straight cut plane it will cut threw the wall on the opposite side of the hall.  It would be hard to turn off everything I don't want to see but that might be the only way to do it.
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Making view titles reference each elevation
Mon, Oct 21, 2013 at 7:30:20 AM
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW
Mon, Jul 29, 2013 at 4:50:17 PM
Transfer Elevation View to a New Project
Fri, Jun 10, 2011 at 7:36:27 PM
Changing Elevation Parent View
Tue, Nov 9, 2010 at 4:35:05 PM
Page generation time: 1.5204
