Forums >> Community >> The Studio >> a challenging question
Thu, Mar 10, 2005 at 8:36:14 AM | a challenging question
moedubai
how to create a cornice or parapet on a wall that is curved on a radius and arched on the top.Create Sweep always says error.cant create sweep.even if i pick just one line on the path.imagine the shape of the wall to the crown of wonderwoman(except with the star). ...thanks so much.as this gave me headaches in solving it.
Thu, Mar 10, 2005 at 11:12:54 AM | RE: a challenging question
TomDorner
4.5 Stars: 25 Votes
Is something like this what you are trying to achive? (see attached JPG) The way to do it is place a wall in a view with the curve in plan. Switch to an elevation, draw a reference plane at the angle you want, name the reference plane, attach the top of the wall to the reference plane. Then for the sweep, set your "work plane" to be the reference plane you created earlier. Sketch the 2D sweep path and apply the profile you want to it. Hope this helps. Tom Post edited on 2005-03-10 11:57:31
Fri, Mar 11, 2005 at 3:05:47 AM | RE: a challenging question
fazerneil
4 Stars: 5 Votes
Tom You lost me at "draw a reference plane..." when you say angle you want Can you please be a bit clearer. I have tried method but just not sure . Cheers
Fri, Mar 11, 2005 at 3:08:24 PM | RE: a challenging question
TomDorner
4.5 Stars: 25 Votes
Posted is the Revit file for you to look at. I added some notes to it as well to help explain. Tom
Mon, Mar 14, 2005 at 3:21:06 AM | RE: a challenging question
fazerneil
4 Stars: 5 Votes
Thanks Tom, all is clear now.
Fri, Mar 25, 2005 at 6:44:19 AM | RE: a challenging question
moedubai
tomdinmn, thank u so much for the help!i am an architect here in dubai.thanks 4d time helping us out with revit.i appreciate it.i hope u don't mind if ithrow another question next time. Smile
Fri, Mar 25, 2005 at 10:58:50 AM | RE: a challenging question
TomDorner
4.5 Stars: 25 Votes
I'll answer when I can. Sometimes the workload does not allow the time needed to respond. It is fun to realize that the Revit community is worldwide and that stuff I write in my bedroom at night is getting out to the world. Just glad to help out when I can. Tom
Challenging Roof Strucutre - Any Suggestions?
Tue, Apr 29, 2014 at 9:42:25 AM
Challenging Skillion roof...?!
Wed, Nov 22, 2006 at 6:15:39 AM
Very Very Challenging Complex Roof
Wed, May 24, 2006 at 12:01:41 AM
REVIT MEP SINK AND TOILET CONECTIONS
Fri, Oct 17, 2014 at 9:59:09 AM
Same Wall, Different Problem
Sun, Sep 24, 2006 at 8:00:48 PM
Page generation time: 1.4497
