Forums >> Revit Building >> Technical Support >> 3 sided downspout cut into veneer
Mon, Feb 25, 2008 at 2:50:09 PM | 3 sided downspout cut into veneer
JHanby
3.5 Stars: 3 Votes
We have 3 sided downspouts that cut into the veneer of the exterior wall.  I made the downspout with a void in it to cut the wall but when I insert it the wall it doesn't cut the wall.  I tried the cut geometry with no success.  What am I doing wrong?  Using version 9.1.
Wed, Feb 27, 2008 at 8:01:39 AM | 3 sided downspout cut into veneer
JHanby
3.5 Stars: 3 Votes
Anybody?  Could really use some help on this one.
Wed, Feb 27, 2008 at 8:39:06 AM | 3 sided downspout cut into veneer
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I would suggest using a hosted "Reveal" to cut the geometry out of the wall. You can do sweeps and reveals as vertical or horizontal.
Void Cut Through Integrated Wall Sweep for Downspout
Tue, Sep 16, 2025 at 7:50:28 AM
double sided lift
Fri, Jan 6, 2012 at 6:46:18 AM
Inserting stone into brick veneer
Mon, Nov 13, 2006 at 9:58:31 PM
Four sided gable roof
Wed, Apr 27, 2005 at 6:43:53 PM
Roofs
Mon, Sep 4, 2006 at 2:36:06 PM
Page generation time: 1.2484
