Forums >> Revit Building >> Technical Support >> Different brick color courses
Mon, Feb 25, 2008 at 12:27:06 PM | Different brick color courses
siar6100
I'm would like to have two different colors of brick alternating courses as you go up the wall.  Is there a way to accomplish this with one wall type?
 Essentially every 3rd course I would like to be a different color and the field brick color.
 Thanks!
Mon, Feb 25, 2008 at 4:44:30 PM | Different brick color courses
eldados
eldados Avatar
4.5 Stars: 8 Votes
the only way i can think off right now is to use field region (model lines)...
Integrator
KarelCAD
Tue, Feb 26, 2008 at 9:28:17 AM | Different brick color courses
ince
You can use a monster stacked wall alternating each course between two seperate wall types.  Take the wall type you are using go to it's properties, then hit edit/new, then duplicate and name how you want it, then click the edit structure button, then drop the material selection list, click the default "masonry-brick" then hit the Duplicate button.  Under Shading change the color to the desired color you want.  As far as the surface pattern goes you should be able to edit the pattern file to add an additional hatch like an AR Sand to differentiate your elevations.  But that's a little beyond me I've seen it done to integrate the fire rating and insulation lines within walls but can't figure out yet how it was done.
Tue, Feb 26, 2008 at 10:29:42 AM | Different brick color courses
siar6100
Thanks for the suggestion!
Question on brick soldier courses in gabled ends
Sat, Mar 19, 2016 at 10:31:54 AM
Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
Tue, Jul 24, 2012 at 5:31:29 AM
Rendering
Mon, Jun 30, 2008 at 12:05:17 AM
Revit Hatch Pattern w/ alternating masonry courses?
Tue, Nov 17, 2020 at 2:37:20 PM
Brick Courseing
Wed, Jun 25, 2008 at 11:32:45 AM
Page generation time: 0.3355
