19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Problems importing .dwg or .dxf.................................
Revit 2008-I have a manufacturer's window details that are .dwg's. I am attempting to import them into a Revit detail component family. (Importing straight into the project failed to work.) I get some elements as a .dwg import and completely different elements when it is saved as a .dxf and imported. Both import attempts left out most of the lines. I have exploded the detail and made all lines on layer "0". No luck. Advice? Anyone?
I don't like to directly import these drawings without cleaning them up first. First, REVIT dosn't like polyline arcs and that's what many of these details have. When you explode these dwg's the polyline segments are too small so they will not import. Therefore, I delete these polylines in autocad and make them true arc segments. Second, I blow away all of the super deatailed stuff that really doesn't mater to me. Third, I delete all hatches. And finally, I put all of the lines on the same layer so they come in as one linetype. (I usually change all of these lines to my REVIT linetypes after import.)
Revit Export to AutoCAD DXF/DWG problems with linked files |
Wed, Aug 27, 2008 at 9:42:43 AM
Can't import dwg or dxf to RS2008 |
Wed, May 30, 2007 at 10:36:07 PM
DWG/DXF layers. |
Wed, May 31, 2017 at 7:05:57 AM
Importing DWG or DXF file objects |
Wed, Jul 12, 2006 at 10:45:32 AM
Are there any dwg /dxf files to download, all I see is *.rfa |
Thu, Feb 5, 2009 at 10:12:18 AM
