Forums >> Revit Building >> Technical Support >> Section problem with skp import
Sat, Feb 23, 2008 at 1:02:51 AM | Section problem with skp import
archmike
I am trying to bring a sketchup model into revit so that I can get plans and sections of the project. Whenever I do a section cut it still shows everything behind the section cut line. Have a project do soon so any help with this would be greatly appreciated.
Sat, Feb 23, 2008 at 3:40:42 AM | Section problem with skp import
4 Stars: 205 Votes
put your project in 3D view and see if your sketchup model it's a different level from your revit model
Sat, Feb 23, 2008 at 11:49:53 AM | Section problem with skp import
archmike
I don't have anything that was built in revit. All I want to do is bring a completed skp model into revit and use revit to make the sections. I read somewhere in a forum that it might have something to do with it being a family and you can't section cut through a family. Any ideas?
Sat, Feb 23, 2008 at 4:50:16 PM | Section problem with skp import
NKramer
4 Stars: 9 Votes
Most sketch up models and imports of this type cannot be cut. I dont know how to fix it or if its even considered a bug. But from what I have seen/ found if it wont cut it wont cut. You would have to remodel any entities that you want cut.
Nick
Sun, Feb 24, 2008 at 2:35:49 AM | Section Box?
Snitzybinkleboo
When you draw the section line, there is a red dashed box on one side of the section cut.  Stuff in that box shows up in your section view so modify that box to your liking.
Bringing an SKP file into RAC 2011
Mon, Jul 8, 2013 at 1:41:20 AM
Import AutoCAD or SKP to Revit as 3D masses for light renderings
Mon, Jan 5, 2009 at 6:33:10 PM
Can't import SKP file!
Sun, Feb 8, 2009 at 3:58:59 PM
Import SketchUp
Sun, Feb 8, 2009 at 3:00:23 AM
12
Errors when importing sketchup model into mass
Sat, Dec 6, 2008 at 5:24:14 AM
Page generation time: 1.7491
