Forums >> Revit Building >> Technical Support >> Can you darken every 5' contour line?
Fri, Feb 22, 2008 at 4:00:53 PM | Can you darken every 5' contour line?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is there anyway to do this in the topography?  Linework doesn't work.  Thanks,
Lorne
Denver, CO
Revit Architecture
Mon, Feb 25, 2008 at 10:00:52 AM | Can you darken every 5' contour line?
Yes, you can
First, set the lineweight you want for primary and secondary contours under settings / object styles / topography
Now, under settings / site settings, you need two  contour settings - 1 at 1' increment using the secondary contour lines and one at 5' intervals using the primary contour lines .... (or whichever way you have them configured / named)
Mon, Feb 25, 2008 at 3:47:06 PM | Can you darken every 5' contour line?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Ok that all makes sense. But it is still not showing up when I set the settings accurately? Why not? What am I missing?
Do I need to mess with anything along the top?  'At Intervals of:'  Or passing through elevation?
Thanks,
Lorne
Edited on: Mon, Feb 25, 2008 at 3:51:47 PM
Denver, CO
Revit Architecture
Mon, Feb 25, 2008 at 3:53:44 PM | Can you darken every 5' contour line?
I've used this so I know it works.  On your site settings, do you have the start and stop set large enough to include your contour range?
Also, lineweights are hard to see on a site plan because of the scale.  Zoom in on the lines.
Mon, Feb 25, 2008 at 4:00:46 PM | Can you darken every 5' contour line?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Yes i have my range set to -1000' to +1000'.  My contours are sitting around +- 0'.  I zoomed in, and still nothing.  The image I just posted is my current site settings, and they seem to look exactly as you're saying.  But, still no changes.
Maybe there's something wrong with this file?  Why does Revit work only half the time, it's really frusterating!
Anyways, any other ideas?  Thanks,
Lorne
Denver, CO
Revit Architecture
Mon, Feb 25, 2008 at 4:07:48 PM | Can you darken every 5' contour line?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Well, I'm a fool.   I had a graphic override per view.  I reset it and changed the object overrides.  Now it works.
WWHub you always are the best help!  Thanks
Denver, CO
Revit Architecture
Mon, Feb 25, 2008 at 4:14:10 PM | Can you darken every 5' contour line?
Did you also set your lineweight you want for primary and secondary contours under settings / object styles / topography?  My settings are 1 for secondary and 6 for primary.  You might make that spread even larger until you are assured that it works.
Mon, Feb 25, 2008 at 4:20:54 PM | Can you darken every 5' contour line?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Yes I did.  It's working fine.  I don't need to change that spread.  Looks great.  Thanks again.
Lorne
Denver, CO
Revit Architecture
Mon, Aug 15, 2011 at 9:23:34 AM | Can you darken every 5' contour line?
carlos72
This was frustating for me too. I've adjusted everything per your conversation and still no results.
The last thing to check was the "view range" if this is too big it doesn't work either
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Hide 'Contour' Lines in Modified Sub Element
Tue, Dec 3, 2013 at 9:21:03 AM
Site-contour
Wed, Aug 23, 2006 at 5:57:17 AM
A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
Tue, Nov 22, 2011 at 6:07:37 AM
Linking AutoCAD Site Contour missing 2014
Wed, May 27, 2015 at 7:56:32 AM
Page generation time: 5.2424
