Forums >> Revit Building >> Technical Support >> Cute PDF not working
Fri, Feb 22, 2008 at 3:23:10 PM | Cute PDF not working
RFarley
I am using Revit 2008 and just installed Cute PDF but cannot get any PDF output when trying to plot. I use a HP 1220 printer that only handles 11x17 size, so I went into printers and faxes and created a new printer using a HP 650 plotter and Cute PDF as the output with d-size sheets. Still no PDF. What I do get is a 8.5x11 blank sheet in Acrobat. Have tried all the settings for page size.
Please help. Kind of stuck without this.
Tue, Aug 19, 2008 at 3:05:03 PM | Cute PDF not working
cganiere
cganiere Avatar
Try uninstalling and reinstalling Cute PDF. If that fails try one of the other free PDF writers. Did you install Ghostscript?
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Wed, Feb 8, 2012 at 3:48:53 AM | Cute PDF not working
csteve274
3 Stars: 2 Votes
Hi,You can download the required pdf software here. Check for many more softwares and I hope this might help you. http://www.cutepdf.com/
Thanks
Edited on: Wed, Aug 29, 2012 at 6:57:36 AM
Wed, Feb 8, 2012 at 8:00:54 AM | Cute PDF not working
mansell5
3.5 Stars: 4 Votes
hi rfarley, if you have installed cute pdf , when printing, u select cutepdf as the printer, not another device.
the cute pdf printer gives all paper size options up to and including A1 .
you run the plot routine using cutepdf, then save the pdf to a convenient location (file) as per the prompt, once saved, then u can either email said pdf , or then print that pdf using your hp printer to get a hard copy.
cheers
mansell5
Wed, Feb 8, 2012 at 3:31:23 PM | Cute PDF not working
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
mansell has it correct, you use the CutePDF, as the plotter. I use PDFCreator, also free, and can make other formats which can be useful.
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND??
Thu, Nov 4, 2010 at 9:43:22 AM
batch pdf's
Sun, Aug 21, 2011 at 2:00:55 PM
Viewport titles moving
Mon, Nov 10, 2008 at 10:16:48 AM
multi pdf printing problem
Thu, Apr 17, 2008 at 9:13:22 AM
imported dwg problems printing to PDF
Mon, Dec 3, 2007 at 12:07:36 AM
Page generation time: 2.8550
