Forums >> General Discussion >> Revit Project Management >> How to measure object faces?
Thu, Feb 21, 2008 at 9:05:03 AM | How to measure object faces?
Majlo
Majlo Avatar
Hi everybody,
First I just want to say that this forum is really great, I had a lot of starting problems using Revit, most of them were solved just by simply reading a few threads... So 'till now, I was able to manage my project without asking specific questions here, but... there's always the "BUT"....
As we are doing a reconstruction on a bridge (you've maybe seen some pictures in the gallery), I have to calculate surface areas of my objects... I will explain my problem in short:
If I have a wall 2x1x0.5 meters, Revit gives me gross area surface measurement of 2 m2. But let's say, I want to calculate all the surfaces of the wall - which sums in this case 7 m2 (am I right?). How can I calculate all surfaces of objects in Revit?
Is there a "area face measurement tool"?
Thanks a lot for advising,
greetings from Slovenia,
Milos
Tue, Feb 26, 2008 at 2:38:34 PM | How to measure object faces?
Majlo
Majlo Avatar
No sugestions? hm... at least let me know if you understand what I'm describing...
This information is quite important to me, as I need this "function" (if it exist) quite often... thanks...M
Tue, Feb 26, 2008 at 2:59:29 PM | How to measure object faces?
NKramer
4 Stars: 9 Votes
I believe that you should be able to do something along these lines with material take offs. (View: New: Material Takeoff) It will give the ammount of an entire material accross a project. So it could get complicated if you need surface area per face.
I havent actually tried it yet, but I believe that is what it is there for.
HTH
Nick
Tue, Feb 26, 2008 at 3:51:36 PM | How to measure object faces?
Majlo
Majlo Avatar
Hey that was quick! From now on, I'll always post another post saying it's important to me... hehe... really thanks a lot... I think I'll manage now... this material take off and wall quantities by assembley are probably every thing I'll need, just need to get to know them and maybe change a bit my line of work and that's it... great stuff.. Cya
Imported object transparent faces
Tue, Mar 15, 2011 at 2:44:52 PM
Measure tool running units
Mon, Jan 23, 2017 at 7:21:11 AM
Picking multiple faces when creating walls
Fri, May 6, 2011 at 2:12:40 PM
Tape Measure Properties [ 1 2 ]
Thu, Aug 21, 2014 at 12:15:12 PM
18
Changing Measure
Mon, Jun 4, 2012 at 11:55:54 AM
Page generation time: 1.0103
