Forums >> Revit Building >> Technical Support >> Sheet Fields
Wed, Feb 20, 2008 at 3:40:25 PM | Sheet Fields
Jbreiten
Does anybody know how to delete some of the sheet predefind parameters?  I don't want to see the "Approved By", "Designed By" & "Sheet Issue Date" parameters under the sheet properties.  I know how to add additional fields but it's confusing to see fields that were not using.  I know somebody will add the issue date to the sheet properties instead of the issue date @ the project properties field.  Hopefully there's an easy answer to this question.  Thanks
Schedules combining 2 text fields in to 1
Fri, Aug 10, 2007 at 12:27:28 PM
Multiple dimension fields in schedule
Wed, Aug 24, 2011 at 4:31:08 PM
Adding Window Parameters/Fields for Window Schedule
Fri, Aug 15, 2008 at 1:23:57 PM
Door Schedule Fields Clarification
Mon, Dec 3, 2012 at 7:06:53 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Page generation time: 4.9309
