Forums >> Revit Building >> Technical Support >> "Simple" dimension question?
Wed, Feb 20, 2008 at 2:06:46 PM | "Simple" dimension question?
JHectorne
Our office is currently transitioning to RAC2008 and, as the test driver, I have come up with some issues that I have been giving me some trouble.  I have searched through the forums here, AUGI, several blogs, and Autodesk Discussion Groups to no avail.  If my question has been asked before, please forgive me and kindly direct me to the appropriate thread; if it has not, any and all help would be greatly appreciated.
 When running a dimension using the "entire wall" option (openings-center), I sometimes have a dimension show up at the end of the wall showing 0".  Does anyone know the cause of this and/or a solution?  It's easier to dimension this way than picking all the instances.
 Thanks in advance for your help.
Jim Hectorne
Wed, Feb 20, 2008 at 3:06:17 PM | "Simple" dimension question?
I haven't done this so I don't know wht causes it but you can.  For some reason, there is something include that results in the 0 dimension.  Click on the dimension string and click on edit witness lines.  Go to the area where you have the 0 and watch what is being selected as you tab through what could be dimensioned to there.  Click on the reference that should not be included in the string.
Fri, Feb 29, 2008 at 9:48:32 AM | "Simple" dimension question?
JHectorne
I figured out my dimension problem.  When you select the dim string, the blue grip boxses appear, hover over the box closest to the dim string and a little black grip box will appear.  Right-click on that box, and you can click on the "Delete Witness Line" selection, thus eliminating the 0" dim.  Hope this helps anybody.  I know I have been trying to figure it out for a while now.
"EQ" dimension on either sid eof a fixed dimension [ 1 2 ]
Sun, Aug 24, 2008 at 12:08:50 PM
15
Adding "Suffix" text to dimension strings in 2009
Wed, Jun 4, 2008 at 7:29:28 PM
"Keeping it Simple"
Thu, May 8, 2008 at 8:01:16 AM
Dimension "entire wall"
Fri, Jul 28, 2006 at 3:30:04 AM
Dimensioning to a "Point" at wall intersection in 2008
Wed, Jan 30, 2008 at 9:41:11 AM
Page generation time: 1.2402
