18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Match line and dependent views
3 Posts No Rating |
Hi all, I'm using Revit Architecture 2008. I have an elevation which I need to split into two because it won't fit onto a sheet. So I did it with matchline. My first question is, should I then duplicate two "dependent views" and drag the crop regions to show the part that I want? My second question is, I now have done the above, but I realize the levels will only show on one of the dependent views but not the other. I checked view properties, it's on. Did I do something wrong? Thanks a lot, any help is appreciated.
11 Posts No Rating |
I'm not sure why. Sometimes it works sometimes it doesn't. Another thing you might want to try is using a callout instead of dependant views.
Sections tag |
Mon, Apr 6, 2015 at 9:41:22 AM
Dependent views not the same as Parent view... |
Fri, Jun 16, 2017 at 11:02:18 AM
Dependent Views - My dimensions stink |
Tue, Aug 24, 2010 at 12:49:03 PM
Detail Callout Bubbles and Dependent Views |
Thu, Aug 12, 2010 at 6:51:10 AM
Design options and dependent views? |
Wed, Nov 4, 2009 at 8:26:39 AM
