Forums >> Revit Building >> Technical Support >> unable to delete wall
Tue, Feb 19, 2008 at 10:49:35 AM | unable to delete wall
violet78
violet78 Avatar
In Revit Architecture 2008...
I have a wall that I can move, split, and add in windows.  But, I can't change the wall type, no grips appear when I click on the wall, and I can't even delete it to start over.  Any ideas on how this happened?
Tue, Feb 19, 2008 at 11:00:55 AM | unable to delete wall
Unpin it.  Adjust your zoom until you can see the pin.
Tue, Feb 19, 2008 at 11:06:42 AM | unable to delete wall
violet78
violet78 Avatar
I couldn't find a pin no matter how far in or out I zoomed.  But, I eventually found a view where it would let me delete the wall, so I'm starting from scratch, hopefully with better luck!  Thanks.
Wall Assemblies
Fri, Mar 21, 2014 at 7:11:17 AM
How to delete a link
Thu, Jun 12, 2014 at 3:59:57 PM
Unable to synchronize with central
Thu, Jan 7, 2010 at 9:12:29 AM
Unable to PICK lines from linked file
Thu, Aug 21, 2014 at 8:47:06 AM
REVIT 2015 DELETE FAMILIES FROM FILE BEFORE OPENING IT - UNRECOVERABLE ERROR
Thu, May 12, 2016 at 7:57:15 AM
Page generation time: 1.4543
