Forums >> Revit Building >> Technical Support >> Room Tags - Tagging Multiple Rooms as One
Tue, Feb 19, 2008 at 10:08:40 AM | Room Tags - Tagging Multiple Rooms as One
otisarch
Using Revit 2008
I was wondering if its possible to define a room tag so that encompasses more then one "room". For instance, I am currently working on a Hotel project. I am looking to define each unit of the hotel as a room including the area in the bathroom and closet spaces. The current room tag only allows me to tag the main space and I have to define the bathroom and the closet as an additional room unto themselves. Can you somehow combine the rooms to form one room or edit the boundaries of a room to define additional space. Thanks in advance.
Tue, Feb 19, 2008 at 10:57:13 AM | Room Tags - Tagging Multiple Rooms as One
Uncheck the room bounding properties of the wall between your rooms and they will all become one.
Tue, Feb 19, 2008 at 1:25:28 PM | Room Tags - Tagging Multiple Rooms as One
otisarch
Worked... Thanks!
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Room Tags - Tagging all Rooms at Once??
Mon, Sep 17, 2012 at 11:40:17 AM
tagging rooms in linked files
Mon, Jan 13, 2014 at 3:26:05 PM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
DELETING ROOMS WITHOUT VISIBLE TAGS
Thu, May 4, 2006 at 6:59:11 AM
Page generation time: 2.2467
