Forums >> Revit Building >> Technical Support >> Detail/Section Heads and Tails Not Connecting?
Tue, Feb 19, 2008 at 9:18:40 AM | Detail/Section Heads and Tails Not Connecting?
andymeyer50
Our office made our own detail/section bubbles that are a bit smaller than the standard ones that come loaded in Revit. Now when I place a new detail cut in our drawing the line connecting the tail to the bubble is not actually touching the bubble head. I made our new bubbles 1/16" smaller in diameter and now the line is 1/16" short of the bubble. It still acts like it is connected but does not display the correct way. How can I fix this?
Thu, May 6, 2010 at 9:33:14 AM | Detail/Section Heads and Tails Not Connecting?
BDerrick
3.5 Stars: 3 Votes
*bump*.. having the same issue here
Thu, May 6, 2010 at 9:59:22 AM | Detail/Section Heads and Tails Not Connecting?
andymeyer50
I can't remember exactly but I believe this was the fix. When you are editing the detail buble you have to move it over the same increment you shrink it by. So if your circle got an 1/8" smaller (radius) then you need to move the whole bubble over an 1/8" to the right (I believe). The line is preset in the software to terminate at the same point. Since you can't move the line you have to reposition the bubble in the family editor. Hope this helps...
Thu, May 6, 2010 at 12:55:25 PM | Detail/Section Heads and Tails Not Connecting?
TomDorner
4.5 Stars: 25 Votes
When you edit the family, be sure to go to the VG (visibility graphics), go to the annotations tab and make sure reference planes are turned on.  Most OTB Revit families of the annotation type have reference planes turned off.  The insertion point of the family will be where the reference planes that are set to "defines origin" intersect.  Typically in an annotation family there are only two reference planes so it is an easy task to find them.  Make sure your circle's quadrant is on the intersection of the reference planes.
HTH
Tom
www.reviteer.com   http://twitter.com/Reviteer
Fri, May 7, 2010 at 8:02:49 AM | Detail/Section Heads and Tails Not Connecting?
andymeyer50
That's what it was! Now I remember.....yep, turn on the reference planes!
Section Cut heads and tails automatically toggle on when you adjust crop region
Wed, Oct 10, 2007 at 11:45:19 AM
Section and Detail Tails
Sun, Jun 18, 2006 at 9:30:05 PM
Section Cut tails
Wed, Mar 28, 2007 at 1:46:10 PM
Revit 2009 : Section Tails: How to create custom Section Tails
Thu, Jul 17, 2008 at 3:25:05 PM
Section Heads
Sat, Jun 10, 2006 at 9:49:47 PM
Page generation time: 0.3441
