31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> scheduling dissimilar components
2 Posts No Rating |
I may have dug myself a hole and need some help if it's out there. I'm working on a project that has large expanses of full height windows as well as more traditional punched openings. Currently I'm using wall based window components for the punched openings and generic 3d model components for the full height windows. So far it has worked beautifully, but...It is now time to schedule my windows and I'm realizing that the schedules for each component category work independently. Does anyone know of a way to easily/efficiently combine two dissimilar components types into the same schedule? Basically, I want a generic component to think it's a window. Any help would be appreciated. Thank you.
My first thought is to change the category of your generic components to "windows". If they are families you created in the family editor, open them there and go to "setttings" "family categories & parameters" then change your family type to a "window". Save the family and re-load into your project. If they are in-place families, edit them and follow the same procedure.
Try and see if this works.
Tom
2 Posts No Rating |
Thanks Tom. Now everything works perfectly. Your tip opened up a whole new world for me.
admin
You can also create "multi-category schedules" if for some reason you don't want to switch the category of your in-place elements. This allows you to schedule anything in your project with the same parameters.
Hiroshi Jacobs
The Catholic University of America |
Revit array with dissimilar elements? |
Sat, Oct 1, 2011 at 1:03:03 AM
Scheduling Components |
Wed, Jan 9, 2008 at 11:24:52 AM
Scheduling Components within Families |
Tue, Dec 2, 2008 at 10:55:13 AM
Scheduling Nested Families |
Mon, Mar 9, 2020 at 2:46:25 PM
Scheduling Coordinate Points for Complex Geometry |
Fri, Jan 21, 2011 at 10:46:22 AM
