Forums >> Revit Building >> Technical Support >> Auditorium Floor Multiple Slopes
Tue, Feb 19, 2008 at 8:41:00 AM | Auditorium Floor Multiple Slopes
ince
I have an auditorium floor that needs to be drawn like a contour grid where I can define spot elevations.  Anyone know how to draw a floor slab with multiple slopes?
Thu, Feb 21, 2008 at 3:49:30 AM | Auditorium Floor Multiple Slopes
viktork
3 Stars: 2 Votes
Easiest way for me; Draw the floor without slope arrow as you please. Finish. Then select the floor and in the options bar you'll have a couple of things to do...for example "modify sub-elements" and so on. Try that!
By the way it applies to roofs too.
Thu, Feb 21, 2008 at 9:55:13 AM | Auditorium Floor Multiple Slopes
plawrence
viktork is right, there is a Define Points option that allows for spot elevations.  The relative checkbox allows you to either adjust +/- from the floor height or if unchecked, you can do true spot elevations.
Fri, Feb 22, 2008 at 12:31:24 PM | Auditorium Floor Multiple Slopes
ince
Thanks for the posts I'll give it a shot when I have to redraw it after design changes.  I have it in for now, but I had to use create mass with a sweep, due to the floor terminating at both ends along an arc with all points of same elevation, then apply roof face.  And then applied to other floor components based on their highest termination point along the same radius.
Auditorium: multiple levels/slopes slab on grade approach.
Sat, Jan 30, 2010 at 4:20:42 PM
auditorium seat family and sloped floor
Tue, Dec 8, 2009 at 9:54:24 AM
Auditorium Floor
Wed, Aug 10, 2011 at 4:19:50 PM
Floor drain slopes adding lines to the slope when modifying sub elements
Tue, Oct 16, 2012 at 3:55:57 PM
Multiple sloping slab on grade
Wed, Sep 28, 2005 at 11:20:27 PM
Page generation time: 0.4816
