Forums >> Revit Building >> Technical Support >> Model Text as a cut out
Mon, Feb 18, 2008 at 7:18:54 PM | Model Text as a cut out
johnda
Can anyone advised me on how to use model text as a void
Thanks John A
Mon, Feb 18, 2008 at 8:53:25 PM | Model Text as a cut out
coreed
coreed Avatar
4 Stars: 16 Votes
This is from Mr.Spot's site:
1. Simply create your model text as you would normally and set the plane so the text is embedded on the face of the wall or system family that you want to engrave the text on.
2. Use your join geometry tool on the wall and the model text - This makes Revit cutout the model text from the wall.
3. Now just set the material of your model text to have a 100% transparency...
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Feb 19, 2008 at 12:01:22 AM | Model Text as a cut out
johnda
Coreed,
Have you tried this method. If I select the text to be joined then the wall is not selectable.  ???
John A.
Tue, Feb 19, 2008 at 12:33:23 AM | Model Text as a cut out
johnda
Hi once more,
I'll revise my earlier comment. I can create a Model Text Void in a wall in a project, but not in a family. I'm trying to create stenciled signage and if i can make this method work in a family rather than a wall it will mean a lot less work.
But up to now I cant seem to join Model Text to any other 3D object within a Family.
John A
Tue, Feb 19, 2008 at 10:26:54 AM | Model Text as a cut out
coreed
coreed Avatar
4 Stars: 16 Votes
from what i understand it will work with elements defined as Generic models also. i have only used it to engrave in walls.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Model text
Wed, Jun 29, 2016 at 11:03:18 AM
Model Text void
Fri, Sep 19, 2014 at 10:21:30 AM
Text being cut in the corner
Mon, Apr 24, 2017 at 10:02:08 AM
missing text
Thu, Dec 19, 2019 at 3:35:19 PM
Model Cut Pattern?
Wed, Jan 30, 2013 at 12:16:11 AM
Page generation time: 2.1422
