14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> Titleblock Scaling
18 Posts No Rating |
I am having an issue with titleblocks and partial/composite plans. i have a large garage at 1/8" scale which was duplicated and divided into 4 partial dependant views. the partial plans are fine when placed into the titleblock sheets. however, the composite plan is too large at 1/8" scale. it needs to be 1/16" to fit inside the titleblock. changing the the "master" composite to 1/16" changed each of the dependant partial plans to 1/16" as well blowing up grid bubbles, text, etc. so the question is: can i scale the 1/8" composite plan to 1/16" to fit inside without effecting the partial plans or grids/text/etc?
6 Posts No Rating |
Why not duplicate the view with detailing and then rescale the new composite plan to 1/16". The only downside is that any new notes you put on the plans won't show up on the composite plan.
i've considered that as an option. just wanted to see what my options were...
I was hoping that you could have different scales as well. After some thought I came to the conclusion that it shouldn't matter if I duplicate with detailing for the composite plan as much of the annotaion on the enlarged plans will not be shown on the composite plans anyway.
I think that TJ has the correct idea. We have always just shown the floor plan (model elements only) in our key plan and then annotate the enlarged segments. It could have to do with the complexity of the plans that we are dealing with, but I wouldnt want to show all of my keynotes on the key plan. It would end up looking like mud. Nick
Titleblock scaling in model space (AutoCAD) |
Mon, Nov 8, 2010 at 10:44:00 AM
Titleblock resized after export |
Fri, Feb 7, 2014 at 8:40:39 AM
Getting Titleblock in centre of page |
Tue, Mar 30, 2010 at 7:13:05 AM
Titleblock question |
Thu, Jul 2, 2009 at 4:23:14 PM
Titleblock Parameters |
Tue, Apr 19, 2005 at 11:55:06 AM
