Forums >> Revit Building >> Technical Support >> overhead lines
Sun, Feb 17, 2008 at 3:00:20 PM | overhead lines
vfok
Hello,
I have overhead detail lines. I want them to appear above walls/doors/anything the model.
Does anyone know how to 'send it to front'?
Any help appriciated!
vf
Mon, Feb 18, 2008 at 3:54:33 PM | overhead lines
niro
if I understnad you correctly, you can turn on the RCP overlay and use linework to assign lines you like to see on your plan.  in this case perhaps hidden line to represent overhead lines.  after you assign the line you will then turn off the overlay and the hidden line will stay on.
warning: the overhead lines are the actual objects, so be careful when you move or delete them.
Tue, Feb 19, 2008 at 10:19:45 AM | overhead lines
vfok
Hey Niro,
Thanks for the response,
but I guess i mis-communicated what I'm trying to achieve,
The model lines that I create appear underneath actual 3 dimensional objects (walls, doors, etc.), I want the model lines to appear above these objects.
Thanks for taking the time (anyone!)
vf
Tue, Feb 19, 2008 at 11:06:49 AM | overhead lines
The model lines will have to be created on a plane that is at the level you want them to be.
Fri, Feb 22, 2008 at 11:55:18 AM | overhead lines
vfok
Thanks both of you guys,
I got it working at the help of you guys.
Thanks again!
Tue, Jun 3, 2008 at 5:22:13 PM | niro
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Quoting niro from 2008-02-18 15:54:33
How do you get an "Overlay" to turn on?  I try to go and turn on the RCP Underlay but my RCPs don't show up inthe view properties.  How do I get the RCP on or off as an underlay to accomplish what you're explaining?  Thanks,
Lorne
Denver, CO
Revit Architecture
Tue, Jun 3, 2008 at 5:23:47 PM | overhead lines
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
nevermind I got it.  Select the plan then select RCP under that.
Denver, CO
Revit Architecture
Roof Overhead Lines
Wed, Feb 17, 2010 at 8:36:00 PM
Overhead Door Family
Thu, Nov 1, 2007 at 8:42:53 AM
OverHead Door creation Rev 2009
Mon, Jun 27, 2011 at 9:34:37 AM
Porch Rack - best practice?
Thu, Jun 18, 2015 at 10:58:36 AM
Overlay?
Mon, Jul 22, 2013 at 12:07:51 PM
Page generation time: 2.9798
