Forums >> Revit Building >> Technical Support >> Brick Quoins
Wed, Mar 9, 2005 at 9:37:39 AM | Brick Quoins
Will9000
4 Stars: 5 Votes
Does anyone know how to incorporate brick quoins? if so your help be very much appreciated
Thu, Mar 10, 2005 at 8:56:28 AM | RE: Brick Quoins
Tanis
If you only need to show Quoins in an Elevation you can create a filled region with a brick pattern. But if you need to create Quoins in a 3-D view, create a new family and give a material with a pattern, so you can change from brick to conc. if needed. I have included the quoin I always use.
Thu, Mar 10, 2005 at 11:05:18 AM | RE: Brick Quoins
Will9000
4 Stars: 5 Votes
Thanks for your help, but how come i cant load it up from my wall family?
Thu, Mar 10, 2005 at 11:26:03 AM | RE: Brick Quoins
TomDorner
4.5 Stars: 25 Votes
The quoin Tanis provided is a generic model that needs to be placed as a component. You will need to place it, align lock copy as required the same as any other Revit component. Tom Post edited on 2005-03-10 11:26:29 Post edited on 2005-03-10 11:26:56
Mon, Mar 14, 2005 at 11:09:59 AM | RE: Brick Quoins
Will9000
4 Stars: 5 Votes
Thanks
Model Pattern Not Moving Independently
Mon, Dec 3, 2012 at 1:23:46 PM
Parametric quoins (tutorial video)
Mon, Dec 12, 2016 at 1:08:29 PM
Adjust Brick veener to move down agianst the brick ledge.
Thu, Jul 26, 2018 at 2:23:13 PM
Brick Colour
Mon, Jan 13, 2014 at 9:27:03 AM
brick sill below window on brick wall
Thu, Mar 13, 2008 at 6:10:23 PM
Page generation time: 3.6337
