Forums >> Revit Building >> Technical Support >> Interior Elevation Tag with Leader
Fri, Feb 15, 2008 at 6:54:21 PM | Interior Elevation Tag with Leader
gigils
Can I add a leader to the interior elevation tag?
Sun, Feb 17, 2008 at 8:37:28 PM | Interior Elevation Tag with Leader
gigils
we are using revit architecture 2008
Mon, Feb 18, 2008 at 1:28:24 AM | Interior Elevation Tag with Leader
eldados
eldados Avatar
4.5 Stars: 8 Votes
no you can't.
just out of intrest, why would you? are you running out of space? try to create a small elevation tag
Integrator
KarelCAD
Mon, Feb 18, 2008 at 8:53:49 AM | Interior Elevation Tag with Leader
gigils
Thank you for your time and response.  i have created a tag that is as small as it can be to still fit the elevation number.  however,  we have a small powder room, a pantry, and a mudroom that are getting a little crowded - trying to avoid having to do a separate larger scale plan of these rooms.  room tags have embedded leaders so they can get kicked out of the room.
Fri, Sep 26, 2008 at 10:55:37 AM | Interior Elevation Tag with Leader
JamesM
Would like to bump this up, as I am trying to figure this out as well, any solutions yet?
Again Revit Arch '08 is being used. Our annotation floor plans can get a bit crowded sometimes and its nice to have this feature
Fri, Sep 26, 2008 at 11:06:55 AM | Interior Elevation Tag with Leader
Why not just move the elevation tag out of the room and add linewrork.
Fri, Oct 3, 2008 at 1:03:37 PM | Interior Elevation Tag with Leader
gigils
that would make the idea behind revit again resort back to autocad.  the revit way would be "smart" so that another user could move the tag and not have to redraw the linework - the way revit currently works with room tags.
we have not found a solution - we ended up doing detail plans of the rooms to fit everything in the space and still be legible at the printed scale.
Interior Elevation Tag - adding Leader
Sun, Feb 17, 2008 at 8:36:29 PM
Leader for interior elevation tag
Wed, Jan 21, 2015 at 9:47:26 AM
Elevation Tag - Leader Problem
Thu, May 17, 2012 at 5:48:20 PM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
Interior Elevation Tags
Mon, Jul 21, 2025 at 11:28:06 AM
Page generation time: 3.5138
