10 Users Online (8 Members):
Forums >> Community >> Newbies >> Revit Template Setup Information
42 Posts No Rating |
Hello I have been working with Revit Arch. 2008 off and on for a few months, and I created the start of an office template. I created several stair setups (joist size, clg. hts., desired # of risers, actual tread depth); when I go to create a set of stairs in a plan, all I really need to do is specify the top level and the width of the stairs. My question is not: was this necessary, overkill, or user preference? I'm not looking for an answer per se, more interested in opinions. Thanks.
Usually we just have one stair - the code minimum. If you need different stairs then they are created on a case by case basis. The larger your template is, the slower every project will be until you purge the unused items.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG |
I agree with cganiere, we have about 2 types in our template, open tread, closed tread. What we do is, if we create a new type in a project, at the end of the project copy it to a new project file called Stair types. Just go to a floor plan and copy and paste into into a project file that contains all your stair types. It keeps a record of them, but keeps em out of your template. You can then copy and paste back into a new project if someone needs them and they can see all your examples at once. There is in fact a file under the "Revit Help and Instruction samples" on the revit content website http://revit.autodesk.com/library/html/index.html that has Stair, railing and roof examples, this is just like ours. HTH
Family Template Selection/Information |
Thu, Sep 10, 2009 at 12:16:17 PM
sheets pre set in template |
Tue, Apr 10, 2007 at 11:36:32 AM
Revit Template Cost |
Fri, May 6, 2016 at 9:44:02 PM
updating template? |
Sat, Apr 29, 2006 at 10:01:29 PM
Settings - Project Information help |
Sun, Apr 17, 2005 at 10:24:54 PM
