Forums >> Revit Building >> Technical Support >> Rayfront or Lightscape
Wed, Mar 9, 2005 at 6:43:57 AM | Rayfront or Lightscape
MattyB
Is there an easy way to set up your 3D revit model so that the layers, when brought into AutoCAD are all different eg the window frames can be distinguisged from the glcurseand different glcurse are on different layers. I'm wanting to know this so I can then import the AutoCAD files into Rayfront and Lightscape.\ I suppose im asking if anyone knows how to use Lightscape or Rayfront using a revit model instead of an AutoCAD Post edited on 2005-03-09 06:47:30
Matty B
Wed, Mar 9, 2005 at 8:27:08 AM | RE: Rayfront or Lightscape
arnosandoval
5 Stars: 3 Votes
If you go to File-export/import settings-export lines dwg/dfx, you can see and change the linetype, layers that the objects in your model are exported to, when you export to Autocad. Hope this helps.
Virtual Environment VS. Ecotect
Mon, May 25, 2009 at 9:52:25 AM
My first project in Revit - what do you think
Thu, Jan 12, 2006 at 1:12:46 PM
Artificial Lights DO NOT turn on in rendered scene
Sun, Jul 13, 2008 at 11:03:42 PM
Hardware upgrades and Revit
Tue, Feb 27, 2007 at 9:26:36 AM
Exterior Lighting
Fri, Jul 8, 2005 at 5:22:02 PM
Page generation time: 2.1455
