Forums >> Revit Building >> Technical Support >> WINDOW FAMILLIES
Fri, Jan 9, 2004 at 12:22:39 PM | WINDOW FAMILLIES
Bimman
Bimman Avatar
1 Stars: 2 Votes
how would i set a window to be installed by a core boundry rather than wall centerline the default window temp is set to center front/back for the refernce plane. can i change that to show core boundry reference planes.
PWD
Fri, Jan 9, 2004 at 1:05:38 PM | RE: WINDOW FAMILLIES
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I don't know if this is possible... can I ask why you want to do this?
Hiroshi Jacobs
The Catholic University of America
Fri, Jan 9, 2004 at 1:18:31 PM | RE: WINDOW FAMILLIES
Bimman
Bimman Avatar
1 Stars: 2 Votes
our windows are installed on the face of the 7/16" osb on the stud wall. the window unit actually sticks out 1 " past the face of the osb. the windows from revit are based off of the centerline of the wall and install on the finish face and not the ccore face. depending on exterioir finish this dimm can be way off. after i posted i went in the wall discription in the window rfa and assigned layers to the 6" generic wall and made it 2X4 with siding. then cut a section and set a reference plane to the outside core boundry which i alligned my inside edge of a nailing flange to in order to have the window in the same place no matter which wall i inserted into.
PWD
Fri, Jan 9, 2004 at 1:54:18 PM | RE: WINDOW FAMILLIES
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
that was a smart move... sometimes you have to be a little inventive.
Hiroshi Jacobs
Famillies - Cannot link nested file parameters to host
Fri, Jan 11, 2013 at 9:55:44 AM
REVIT CITY Library Uploads suggestion
Thu, Nov 11, 2010 at 10:28:07 AM
Window sashes with different window numbers in the window schedule
Tue, Mar 19, 2024 at 11:49:53 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
LOOKING THROUGH THE WINDOW, SCHEDULE
Sun, Dec 19, 2004 at 7:03:39 PM
Page generation time: 0.1485
