12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Imperial to Metric
12 Posts No Rating |
This may be a simple yes or no question. When I installed Revit I believe I made it imperial. Now I have a drawing I need to reproduce thats all metric. Is there a unit setting somewhere, or would I have to re-install Revit in metric?
NEVERMIND, I'm an idiot, it was a simple change!!!!!
I have the same problem...how did you make that change?
You want to change in the settings-Options-File Locations-in Default Template files - Browse the Imperial templates to Metric Templates and choose "DefaultMetric", then you gonna work with the Metric System..., if you already have a file with Imperial system so Write UN the change the format "Feet and fractional inches to Meters or Millimeters"
showing metric and imperial elevations |
Thu, Jun 3, 2010 at 3:34:46 PM
Change from Metric to Imperial |
Sun, Feb 17, 2013 at 9:26:03 AM
Imperial metric question RAC2009 |
Fri, Jan 9, 2009 at 11:35:51 AM
Imperial and Metric sheets and views |
Thu, Dec 16, 2010 at 3:32:05 PM
Change imperial to metric |
Wed, Mar 11, 2009 at 9:20:24 AM
