Forums >> Revit Building >> Technical Support >> Level 1 room boundries showing up in foundation level
Fri, Feb 15, 2008 at 9:31:36 AM | Level 1 room boundries showing up in foundation level
eman3693
I am trying to draw a basement plan for a retail building (with basement).  For some reason the area "polylines" from the level 1 tenant spaces are showing up on the foundation level.  When I tried to clipboard past things from level 1 to the foundation, I get the error "Highlighted walls overlap. Color fills, room tags and room areas may not behave correctly. Use Cut Geometry to embed one wall within the other."  I just found out that when pasting to "current level" (foundation) is pasted on top of the level 1 plans.  I must have not set up my basement plan properly.  Althouh in 3D view it shows correctly.  Any pointers on getting this sraightened out?  I would like to copy the stairs, some walls, and the elevator shafts to the basement.  Thanks.  (Revit Arch 0Shadey
Foundation plan/level view (R2013)
Wed, Nov 14, 2012 at 12:19:31 PM
Associated level of room
Tue, Jan 2, 2007 at 6:29:59 PM
Foundation Top of Footing (when Level is something other than 0'-0")
Fri, Jan 29, 2016 at 1:40:13 PM
Can't get Rooms (Room Tags) on Second Level...
Sat, Mar 21, 2009 at 3:44:40 PM
Room not showing
Tue, Mar 25, 2025 at 7:06:37 PM
Page generation time: 0.4069
