12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> text in elevation
When setting up your work levels in elevation view at the start of the project, does anyone know how to change the text size as with too many different levels it gets confusing?
You would have to create a family for your level text. You would just need to open the default level family from the Reivt library and save it as something else, then you can change the text size to whatever size you need to. Once imported in the project you can have different sizes for text. Hope this was helpful.
Thanks for the reply, but i cant get it too work?
When i set up the levels in the elevation view, it wont let me change the text properties, i've tried edit and duplicate but there is no active command to change the size of the text.
Okay, open from Annnotations-Levels.rfa, from the defaul revit library
Make your changes in that file. Save as. Then load that file into your project. Go to your elevations and click on the level datum line to highlight. Select and go to properties. Change the family type to the family type that you have changed. Let me know if you have any more problems.
elevation mark stacks text |
Tue, May 9, 2017 at 11:38:59 PM
Spot Elevation Forced Text |
Fri, Apr 22, 2011 at 1:04:00 PM
ADDING TEXT TO A FAMILY ELEVATION/PLAN |
Thu, Jul 16, 2015 at 11:28:36 AM
cant copy text between elevations |
Fri, Apr 27, 2007 at 6:52:11 AM
Spot Elevation Text |
Tue, Mar 8, 2011 at 7:45:39 PM
