Forums >> General Discussion >> Revit Project Management >> Remove from view structural blue dots?
Wed, Feb 13, 2008 at 7:54:48 AM | Remove from view structural blue dots?
ericg
Hi everybody,
 I'm having a probleme with bleu dots showing up. Mostly in my the file linked to a another file. I have done some research in the help to find nothing.
Any help please.
 revit masters are next gen builders
EricG
Mon, Feb 25, 2008 at 4:49:39 PM | Remove from view structural blue dots?
TABEST
4 Stars: 4 Votes
I'm not sure of the reason, but this occurs in linked files.  When this happens, I've noticed it has a tendancy to do with overriding the view depth of the linked file, though not always.  if you undo the overrides to the linked file, then the blue dots go away.  Make all of the overrides that you are performing for your linked file at once, and i've noticed that this usually helps, though not always.  good luck
Tue, Feb 26, 2008 at 7:49:26 AM | Remove from view structural blue dots?
ericg
I did found how to remove the dots. It happens in the gaphique visibility. Look the attached file to see how to unwrap to the checkmark to remove the visbilties of those dots.
Good day my friends.
Tue, Feb 26, 2008 at 11:45:50 AM | Remove from view structural blue dots?
JHanby
3.5 Stars: 3 Votes
Great!! Thanks ericg!!  Always wondered how to get rid to those blue dots.
Edited on: Tue, Feb 26, 2008 at 11:46:19 AM
blue dots in linework
Wed, Aug 18, 2010 at 4:13:09 AM
Black or Blue dots in linked Structure file
Sun, Oct 29, 2006 at 8:00:27 PM
Visibility of Revit Links
Thu, Oct 15, 2009 at 4:50:21 PM
Adjusting section lines
Wed, Aug 9, 2006 at 12:27:06 AM
Column shows blue circle on axis in plan view?
Tue, Nov 7, 2017 at 4:42:43 PM
Page generation time: 3.5738
