Forums >> General Discussion >> Wishlist >> Copy/Monitor
Tue, Feb 12, 2008 at 2:37:43 PM | Copy/Monitor
kwanser
Another item i feel that should be implemented into Revit would be when you are copy/monitoring, there always seems to be an issue with Mateials and duplicate types.  You should be able to say "Yes To All"  for these materials so you don't have to go through each type and piece of the building.  On another note, when deleting what you have copied to replace with new when the copy/monitor tool doesn't work, you should be able to select all and delete.
If there is a way to do any of this, please let me know.  I am working on a 6-story building and this takes forever.
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Rev Arch 2009 conultants elelments in copy monitor
Wed, Aug 31, 2011 at 2:21:36 PM
Page generation time: 7.5695
