Forums >> Revit Building >> Technical Support >> Irregular stone wall
Tue, Mar 8, 2005 at 9:31:53 AM | Irregular stone wall
Will9000
4 Stars: 5 Votes
Hi, Im trying to show a stone wall, (which i can create with the render image) but a stone wall that has partly been demolished so it is seen on elevation as an irregular tapered wall. Any suggestions on how to do this? Many thanks
Tue, Mar 8, 2005 at 10:45:50 AM | RE: Irregular stone wall
fazerneil
4 Stars: 5 Votes
If you mean demolished along its length/height, just edit the elevation profile of the wall. Pick wall, edit profile and then draw the taper you want. This will affect any joins the wall may already have with roofs etc.
Wed, Mar 9, 2005 at 6:34:42 AM | RE: Irregular stone wall
Will9000
4 Stars: 5 Votes
SORRY I MEAN A WALL THAT IS NOT ATTACHED TO A ROOF, A FREESTANDING WALL THAT HAS BEEN DEMOLISHED IN PART AND IS TAPERED IRREGULAR. HOW DO YOU TAPER THE WALL
Wed, Mar 9, 2005 at 8:58:09 AM | RE: Irregular stone wall
arnosandoval
5 Stars: 3 Votes
You can do one of two things, you can create a in-place wall family and have the mcursetaper as a blend. Also you can create a mcursewith the angles that you want and select curtain system by face and pick the surfaces you want to make, then you just change the panel style to whatever material you want, thickness, etc. and viola you have a sloped wall.
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:58 AM
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Stone walls
Sat, Jan 12, 2013 at 5:40:42 AM
fill patterns and stone walls
Fri, Aug 18, 2006 at 8:54:32 AM
Anyone? Why does stone render wierd here. Same wall on each side of corner
Mon, Nov 17, 2008 at 9:52:12 AM
Page generation time: 6.6427
