Forums >> Revit Building >> Technical Support >> Hiding Certain Doors from a Door Schedule
Mon, Feb 11, 2008 at 8:13:22 PM | Hiding Certain Doors from a Door Schedule
Robles
Does anyone know how to "hide" certain doors in the model from appearing in the door schedule?
I'm working on a remodel project where not all of the doors are being updated (so there is no need to have them represented in the schedule, but still need to see them in the floor plans).   Thanks!
Mon, Feb 11, 2008 at 11:38:17 PM | Hiding Certain Doors from a Door Schedule
puzzle
4 Stars: 10 Votes
You could use phasing. Go to view proerties for the schedule and you see phasing. Make a new phase filter such as new only (in the phasing under settings). Apply this filter and only new windows will appear. Or you could use the filters in the schedule.
Macca
Sunshine Coast
QLD Australia
Tue, Feb 12, 2008 at 12:32:02 PM | Hiding Certain Doors from a Door Schedule
Robles
I'll check this out, thanks.  I tried doing this earlier, but the doors that I didn't want scheduled would dissapear from the plan, too (I still want to see them in the plan view, just not in the schedule view).  Maybe I just wasn't tenacious enough.  I'll play around with the visibility settings some more.  Thanks!
Tue, Feb 12, 2008 at 1:19:18 PM | Hiding Certain Doors from a Door Schedule
TJKENNEDY
3 Stars: 2 Votes
You could just put something in the element comments ("no schedule" or something like that) and filter by that.
Tue, Feb 12, 2008 at 1:28:57 PM | Hiding Certain Doors from a Door Schedule
Robles
Thanks everyone...using a filter worked like a charm and solved my problem from another thread.
Thu, Oct 29, 2009 at 11:01:52 AM | Hiding Certain Doors from a Door Schedule
Hart
Hart Avatar
Hey thanks for the info worked great!
Thu, Nov 19, 2009 at 12:33:07 PM | Hiding Certain Doors from a Door Schedule
JimNoth
Proper phasing would have certainly been the best way to solve this problem.  But other than that, one thing I do with my project files is add a project parameter associated with doors called "Schedule" as a yes/no (check box) value.  Then filter by that.  That way I don't have to fill in the Comment field with one thing when I may need it for another.
Fri, Nov 20, 2009 at 12:54:37 AM | Hiding Certain Doors from a Door Schedule
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
I like to Tag the doors with a number that starts with X (X1, X2) then just tell the schedule to exclude anythings that starts with X
J. Allen Ball
Revit Architecture 2010 Certified Professional
Mon, Jun 25, 2012 at 5:02:08 PM | Hiding Certain Doors from a Door Schedule
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
The "filter by comment" idea worked brilliant for me. I simply wrote "Do Not Schedule" in the comment feild of the door, then added the a filter to the schedule that works by comment using "Does Not Equal: Do Not Schedule"  The beauty of this method is that no editing of any door families is necessary, and that the comment can be applied to any and all door families.
Tue, Jun 26, 2012 at 7:10:19 AM | Hiding Certain Doors from a Door Schedule
We add a project parameter to all categories through our template called "Do NOT Schedule".  You can then use this to filter any schedule.
Doors not appearing in door schedule... Help
Thu, May 30, 2013 at 11:58:43 PM
Manipulating the door schedule
Wed, Jun 26, 2013 at 10:35:33 PM
11
Door Schedule help.
Thu, Sep 10, 2015 at 1:41:52 PM
Storefront Doors in Door Schedule
Wed, Sep 9, 2009 at 4:32:17 PM
room names not being picked up in door schedule
Mon, Apr 21, 2008 at 10:26:48 AM
Page generation time: 1.4436
