Forums >> Revit Building >> Technical Support >> lots of questions
Tue, Mar 8, 2005 at 2:44:14 AM | lots of questions
ridhs
im sorry but i have tons of questions.. here goes... : 1. is there a way i can edit what the doors or windows or openings look like in plan view? as in if say i wanna change the swing of the door.. or i wanna make sure the lines above are shown 2. i have a two storey bldg.. i drew the stairs on the ground floor but for some reason it wont show on the first floor plans. i checked the view and vut plane etc.. dunno.. 3. is there a way to change the cut level for an individual wall? say i have a window below 3' but i want ti to appear in te plan? 4. in the 3d views is it possible to view just one floor at time without haveing to click on individual walls etc and hiding them? 5. any suggestions for wats the best way to draw a trellis? well thats all.. for now Smile thanx!!
Tue, Mar 8, 2005 at 3:59:43 AM | RE: lots of questions
fazerneil
4 Stars: 5 Votes
1. The advanced tutorials in revit 7 (?) give full idea on creating door swings. The basic tutorials take you through door/window families. A lot of what you see in each view will be down to both the way you create the family, setting detail level of each oject and also your view parameters in terms of view range in view properties 2. Sorry to ask simple questions: Have cut a hole out of first floor Have you checked section to be sure stairs go up to floor level 3. Change your view range parameters in view properties. May need slight playing around to get full range required. 4. Again in view properties, switch on section box for which you can move sides of a cube to get just where you want the building cut in that view 5. Create it as a family drawing it in elevation. Hope these help.
Wed, Mar 9, 2005 at 11:35:04 PM | RE: lots of questions
ridhs
thanx that really helped... jus one question though.. i tried to make a trellis as a new family but somehow when i bring it into my drawing i can see it in 3d view but not in plan.. i tried to play around with the view setting but im not too familiar with it.. im sure its a matter of changing the viewing height but im not sure how to do that..wld appreciate ur help thanx! i think the problem is that the cut plane is set to 90 for my floor plan dwg and the trellis is at a ht of 240.. but if i change the cut height then itll screw up the rest of the dwg.. is there a way i can change the cut plane for a certain object only??? Post edited on 2005-03-10 00:08:48
Thu, Mar 10, 2005 at 12:44:35 AM | RE: lots of questions
ale02
ale02 Avatar
3 Stars: 3 Votes
I believe it is view range issue. try and see..go to view properties>view range>reset cut plan until you can see the trellies For the workaroound, to be frank, I never try this before but I believe it can work as there are some example people using it for show roof eaves lines over Try open up for family, at plan view, draw a symbolic lines at level 0m to indicate trellies lines over, then align to your trellis edges After that, reload your trellis family to your project.. Hope this help
Life is never easy but nor it should be complex. Just stay simple Smile
Thu, Mar 10, 2005 at 3:18:34 AM | RE: lots of questions
ridhs
i tried that but it doesnt help.. cuz if i change the cut plane my doors and windwos dont show
Thu, Mar 10, 2005 at 10:45:54 AM | RE: lots of questions
fazerneil
4 Stars: 5 Votes
Try leaving cut plane as it is to suit main components. Play around with top and bottom offset values. If you know your trellis bottom is above 240 height, set top offset to just above this figure Remember to check where you are offsetting from). If trellis still does not appear then it would seem detail level settings on your original trellis family could be wrcausing the problem. If you attach family to next post we could check it out.
Thu, Mar 10, 2005 at 1:08:16 PM | RE: lots of questions
Bimman
Bimman Avatar
1 Stars: 2 Votes
have you tried adding a plan region to show items above your standard cut plane.
PWD
Thu, Mar 10, 2005 at 8:11:48 PM | RE: lots of questions
ale02
ale02 Avatar
3 Stars: 3 Votes
If you can view your trellies in 3D view, then there should be nothing wrong with your family, it is just a matter of how to present it in plan view, (In this case, I think you still want to remain the original view plan but still want to show the trellies above the cut plane) I agree with Bim man, plan region might be a good workaround.. If by showing the symbolic dash lines is sufficient, then try my workaround (but let me know whether it works or not, coz I am yet to try on it, Just knew by theory) try to see the following thread by Mr. Spot, only different is doing it family then reload to project or doing direct on project. (I believe both case should work).. http://www.revitcity.com/forums.php?action=viewthread&thread_id=1048
Basic Questions
Wed, Dec 16, 2009 at 1:01:10 AM
Almost an underlay
Wed, Mar 29, 2006 at 10:50:47 PM
Arriving at the Forum
Tue, Oct 20, 2020 at 8:05:55 AM
Still Looking for Revit Content Creation help
Tue, Mar 26, 2013 at 4:58:02 PM
Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
Tue, May 22, 2012 at 7:39:03 AM
Page generation time: 0.1442
