8 Users Online (6 Members):
Forums >> Revit Structure >> Tips & Tricks >> Array within Family
Thought this might be useful to any new Revit users creating Families with arrays... http://www.revitup.co.za/main/page_tips__tricks_families__arrays.html Justin
Thanks for that, just a couple of comments  1- I would use the Beam system to array thos rafters, much simpler and can be used for many applications. 2- Check out Mr Spot's Nested array tutorial to a more in depth lesson... Cheers,
Good point about the Beam System.. I have used this, though I created this little example to show how components can be manually arrayed i.e the same principles for this family can be used to create shelving, bookcases etc. Thanks Justin
Family w/ Array Formula |
Fri, Mar 23, 2007 at 9:29:37 AM
Radial Array in a Family |
Mon, Apr 11, 2005 at 8:56:12 PM
Array Parameter within Family |
Thu, Aug 7, 2014 at 8:25:09 AM
Parametric Array Constraints |
Tue, Jul 2, 2019 at 7:00:45 AM
Editable nested family inside parametric array host family |
Wed, May 19, 2021 at 8:05:22 AM
