Forums >> Revit Building >> Technical Support >> Subterranean Levels
Fri, Feb 8, 2008 at 4:58:23 PM | Subterranean Levels
revjf
I'm working on a project that has below grade parking levels. The depth from the surface to the top of the parking levels is about 15ft, and I'm trying to model this condition where the parking levels are surrounded by the earth, sort of a tunnel. I think I hit a wall after I found out that building pad doesn't work. Is there any way of modeling this?
Thu, Feb 12, 2009 at 12:31:12 PM | Subterranean Levels
billyjencks
I have a similar situation and I am simply representing the earth with a generic mass. This way you can manipulate it as a simple 3d object rather than the limited grading tools for topo surfaces. Don't know if this is the best way to do it but it has worked for me so far.
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
walls look different on different levels
Thu, Mar 11, 2010 at 2:38:19 PM
Page generation time: 0.1505
