Forums >> Revit Building >> Technical Support >> Roof Intersecting
Fri, Feb 8, 2008 at 11:31:33 AM | Roof Intersecting
rcobbjr
3.5 Stars: 3 Votes
I am using Revit 2008, I have a roof that intersects. Is there a way to "trim" away the part of the roof so it does not appear "under" the other roof? See the attached image. In the image, I removed the walls so you could see what I am talking about. I left the windows so you will know it is a wall there. You should be able to see part of the roof that is showing up under the other roof that is intersecting it.
Fri, Feb 8, 2008 at 12:32:56 PM | Roof Intersecting
mthurnauer
3 Stars: 2 Votes
I don't know if this is the best way, but you can make a void volumne and then, using Cut Geometry, cut out the portion you want to remove.
Intersecting roofs
Mon, Oct 16, 2006 at 8:28:41 AM
Cut Fascia by roof
Mon, Jun 25, 2012 at 10:39:49 AM
intersecting elements problem
Tue, Sep 15, 2009 at 11:25:17 AM
Corrugated Roof on double curved roof form
Fri, Mar 28, 2014 at 2:13:34 PM
Intersecting shapes in Wall edit profile (revit 2012)
Sun, Nov 10, 2013 at 8:42:11 PM
Page generation time: 0.3571
