16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Dimension with Tick and Dot
2 Posts No Rating |
Is it possible to have a Tick and a Dot on the same dimension? Our company standard has always been to have a tick for the wall edge and the dot for the column line. Any thoughts?
admin
I don't think you can do that on the same dimension. However you could use different dimesion strings with different dimension styles to acheive the same effect.
Hiroshi Jacobs
The Catholic University of America |
1 Posts No Rating |
... a bit clunky but it works... Create a detail component - a small square using invisible lines with a short, thin visible centerline called "Gridline Dot Workaround" - Create a linear dimension type with a diagonal  or whatever your standard is) for a tick mark and a dot for the centerline tick mark. - Load the detail component "Gridline Dot Workaround". Place the component in the view you are dimensioning. Align centerline of "Gridline Dot Workaround" with grid line. - Dimension to "Gridline Dot Workaround", positioned over the gridline. You will get your "dot" you've been looking for, while the end without the "Gridline Dot Workaround" will remain a tick.
24 Posts No Rating |
Do you have this detail component that you could share or upload? I am trying to do this, but cannot get the <centerline> line type in the family...
Dimension with both dot & tick |
Mon, Jun 26, 2006 at 10:37:15 AM
Dimension Tick Resize |
Fri, May 12, 2006 at 11:50:56 AM
dimension tick |
Wed, May 5, 2010 at 8:08:41 AM
dimension annotation |
Mon, Feb 20, 2006 at 8:37:23 PM
Dimension tick mark |
Mon, Jul 11, 2005 at 2:31:38 PM
