Forums >> Revit Building >> Technical Support >> Documenting Multiple buildings
Thu, Feb 7, 2008 at 3:19:48 PM | Documenting Multiple buildings
wnorton
Is there a way to draw a building in its own file and then import the model with the documentation (tags, detail lines, sections, callouts, etc...) into another file?  I have multiple buildings that i want to share the same floor plan sheet, but you can't seem to document a linked building, and modelling the buildings in the same file proves to be a hassle, because if the buildings need to shift relative to each other (which has happened twice now) it means moving the models themselves (as opposed to the "Relocate this Project" command) and this causes problems with notes, details, crop regions, etc... which then need to be moved manually...
 Any ideas?
Multiple Buildings - 1 Drawing Set
Wed, Jun 4, 2008 at 1:46:05 PM
LINKING MULTIPLE BUILDINGS INTO ONE PROJECT
Wed, Nov 29, 2006 at 8:04:32 PM
Large project with multiple buildings - file management
Mon, Feb 25, 2013 at 4:32:17 PM
Multiple buildings on one site
Wed, Feb 4, 2009 at 6:52:04 PM
Massing Studies with Multiple Buildings with different levels
Sat, Apr 28, 2012 at 2:32:45 AM
Page generation time: 0.1421
