Forums >> Revit Building >> Technical Support >> Copying doors from one phase to another
Thu, Feb 7, 2008 at 2:29:40 PM | Copying doors from one phase to another
Gyvven
5 Stars: 2 Votes
Using Revit 2008.
I'd like to have all of the doors on my existing phase copied to a new construction phase (being demo'd and replaced). However when I copy aligned it says "instances not cutting anything", but it has no problems inserting a new door where the old one was.
(This has other benefits aside from allowing two door schedules, one with demo doors, another with new. It also allows a link to be copied in a master plan to allow unique door and room numbers to be assigned per building using a phase filter on separate schedules.)
Is there a way this can be done without having to insert a new door at every location?
Phase "new" in plan: doors cut pattern same as wall
Tue, Dec 8, 2015 at 7:40:25 AM
Maintaining "Phase Demolished" properties.
Thu, Jun 18, 2015 at 8:19:39 AM
Elevations in Existing Phase dont show Windows & Doors
Wed, May 6, 2009 at 4:18:46 AM
Existing door reused in proposoed phase
Tue, Oct 14, 2014 at 5:06:49 PM
new doors in existing walls
Wed, Jun 30, 2004 at 3:13:03 PM
Page generation time: 5.4931
