Forums >> Revit Building >> Technical Support >> RPC's don't show in Revit 7.0
Mon, Mar 7, 2005 at 6:00:04 PM | RPC's don't show in Revit 7.0
kugs_m
We have tried bringing in a RPC of people and trees and neither will render. What are we doing wrong?
Mon, Mar 7, 2005 at 7:00:59 PM | RE: RPC's don't show in Revit 7.0
matlock
matlock Avatar
4 Stars: 6 Votes
yea, i have been tryng to make my rpc files to work also, so i followed a post made by MrGG: ----------------------------------------------------------------------------------------- To use your own photos of people, trees, cars.... in Revit you can use RPC Creator - it is freeware but you have to register first. Here is the address: http://www.archvision.com/PublishingTools.cfm 1. You must have at least two images. One with the photo and one with the mask – the alpha channel. You can make them in e.g. Photoshop. And you have to save them as .jpg-images. And they have to end with the number 1 e.g. pram1.jpg and pram_mask1.jpg. 2. If you have an editable .rpc-file to Import into RPC Creator you can get a little help from it. If you look in Revit under Settings > Options > Rendering > Additional rendering material directionaries you hopefully find a path to a map called RPCPeople. Here you can find and save .rpc-files. You can also start from scratch without Importing any .rpc-file. You have to fill in some information in every step in RPC Creator so you can click Next and continue. But there is information about what to fill in so you will certainly manage it. If you only have one image with a mask image you must in Step 4 in RPC Creator choose 0 for image and 0 for the mask – not choosing 0000! You can use 360 images with 360 mask images if you like to and it will be a little more 3D -- but it is not necessary... Just one can do it. Finish with exporting the .rpc file to the directory RPCPeople. You can use other directories too if you have the .rfa-file in the same directory(explained below). 3. You can now open a .rfa-file from the map Entourage in Revit and click Family Types to change the value of the parameter RPC Filename to your own .rpc-file name. Just click the old name and browse for your own .rpc-file. And then save the .rfa-file with a new name. 4. Now you can load the .rfa-file as a component in a Revit project and your image will get the right perspective proportions then you render a scene using the camera. ------------------------------------------------------------------------------------------ but i could not get this to work after many days and hours.... I did however manage to get my indoor plants and stuff to work, modifing plants seems to be much easier, ----------------------------------------------------------------------------------------------- again by MrGG: Mr GG metric Tree Pine --- To the left the isometric verion - To the right the raytraced version - You can do your own version by opening Tree Spruce.rfa in Revit and click Family Types ----- then Plant Name and ----- then Trees and Shrubs/Conifers and then choose a pine ----- and then Plant - New - Use current plant as Template.... And begin to design yourself! ------------------------------------------------------------------------------------------- im still waiting for response of rpc file modification...
Mon, Mar 7, 2005 at 8:05:49 PM | RE: RPC's don't show in Revit 7.0
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Also, Make sure your RPC locations are setup in Settings-->Options-->Rendering tab-->Additional rendering Materials... Make sure there location is setup here otherwise revit wan't know how to render it...
Tue, Mar 8, 2005 at 1:22:53 PM | RE: RPC's don't show in Revit 7.0
matlock
matlock Avatar
4 Stars: 6 Votes
cool YES!!!!! it finally worked thanx Mr spot, it took a little figuring out but the files must go here: C:\Documents and Settings\All Users\Application Data\Autodesk\Revit 7.0\Rendering\AccuRenderRedist I put all the files in there, i dont know if i just needed to put the rfa there, but who cares, it works...
Rpc and revit 7.0
Thu, Mar 10, 2005 at 7:41:12 PM
Rpc Creator made Rpc can't load
Wed, Oct 24, 2012 at 5:12:32 PM
RPC trees not rendering - but show in model
Fri, Mar 2, 2012 at 7:32:16 AM
ArchVision RPC Component not showing in Views only in Renders.
Fri, Sep 4, 2009 at 9:13:28 AM
How to use RPC in revit?
Mon, Jun 18, 2007 at 6:23:37 AM
Page generation time: 1.6708
