Forums >> Revit Building >> Technical Support >> Arched extrusions
Thu, Feb 7, 2008 at 11:32:26 AM | Arched extrusions
atrojniak
I am creating a sweep extrusion to creat a stone sweep that follows my arch windows.  I got this to work for the most part, however, when i draw the paht and then my profile once it creates the sweep it creates a radius corner where it should be 90 degrees.  Any suggestions on how to fix this, i would appreciate, thanks
Thu, Feb 7, 2008 at 1:26:43 PM | Arched extrusions
mthurnauer
3 Stars: 2 Votes
Your problem appears to be because your profile is positioned such that the top of the profile aligns with the path.  If the bottom of your profile aligns with the path then you would not have this problem.  I suspect the you have your profile where you need it, but will need to edit your path.  You should be able to edit path pretty easily with the Offset tool.
my extrusions are transparent?
Tue, Feb 24, 2009 at 5:56:54 PM
where is the help for arched parametric window?!
Thu, Jan 15, 2015 at 6:35:55 PM
Arched Curtain Wall Arched Mullions
Wed, Jan 22, 2020 at 2:13:08 AM
Arched Window
Thu, Sep 29, 2005 at 1:20:55 AM
arched curtain wall
Mon, Feb 26, 2007 at 10:17:47 AM
Page generation time: 1.0719
